Has anyone taken airbag stickers(?) off visors?...
Guest
Posts: n/a
I just waited for a hot day...they peel right off. Any remaining glue can be removed with Goo Gone. I'm sure if you heated up the stickers with a hair dryer or something, they'd come off pretty easily.
W
W
Guest
Posts: n/a
They come off clean, ok on the '00 models - I assume it is the same for all. However, the material is actually pretty rigid. Be careful if you use a fingernail or something, the sticker will slice right up under.
Otherwise it is pretty trivial.
Guest
Posts: n/a
They came off very easily and left no residue. I just held the vinyl down as I pulled each inch of label up to keep from possibly tearing or stretching the vinyl.
When I did my '98 a couple years ago, it did leave some residue to rub off but that one had sat on dealer's lot for several months before I bought it.
Guest
Posts: n/a
Don't pull them off so that the sticker is perpendicular to the visor. I feel this might stretch out the visor material. Instead, try a lower angle (like 30 degrees) and pull back/up at the same time. Mine came off much more easily this way.
Vijay
RS4 (B7 Platform) Discussion
21
02-19-2007 06:12 AM
O.W. Kenobi
03-19-2002 06:56 AM
