Have vagcom, need codes to reset airbag light.
Searched, didn't find any specific vagcom instructions to reset airbag light. I unplugged the seats and plugged them back in, hence the light. Here is my vagcom log:
VAG-COM Version: Release 313.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 3B0 907 551 BQ
Component: 2.8L V6/5V G 0001
Coding: 07201
Shop #: WSC 63351
1 Fault Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Controller: 8D0 959 655 G
Component: Airbag Front+Kopf 2002
Coding: 00306
Shop #: WSC 22161
2 Faults Found:
01217 - Side Airbag Igniter: Driver Side (N199)
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter: Passenger Side (N200)
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02262
Shop #: WSC 22101
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
3 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
31-00 - Open or Short to Ground
01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
End -------------------------------------------------------
Coding: 07201
Shop #: WSC 63351
1 Fault Found:
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 63351
Coding: 00306
Shop #: WSC 22161
2 Faults Found:
Coding: 02262
Shop #: WSC 22101
Coding: 16140
Shop #: WSC 63351
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00102
Shop #: WSC 63351
3 Faults Found:
35-00 - -
Coding: 00012
Shop #: WSC 63351
then click buttons 15-->02-->05.
Then do the same thing on yours with it connected to the car. How'd you get the codes?<ul><li><a href="http://www.ross-tech.com/vag-com/tour/scm_screen.html">http://www.ross-tech.com/vag-com/tour/scm_screen.html</a</li></ul>
barneya4b6
05-25-2006 12:06 AM
