Headlight removal
I own a 1996 Audi A4 2.8L V6 12V
I looked at this article:
https://www.audiworld.com/tech/ext5.shtml
And I cannot find the third Torx screw. To me it seems that it is not there and that the headlight being is being held in by a 3rd screw located on the bottom left (looking straight on) by the radiator.
How do I remove it?
How do I remove it?
there should be a spring clip that is holding it in place. Once you pull out the sidemarker and you will see a bolt that is holding the headlight in place.
thank you for the reply, but there isn't enough clearance to unscrew it. The reason I am doing this is because one of my headlights is way out of wack. It is pointed very high. I tried adjusting it using the hex screws, but that moves the whole lamp.
Any ideas?
Any ideas?
first starting from the seam where the main headlight housing and the sidemarker meet... look straight down from the top. Now look a little more toward the sidemarker side. You will see a white tab. This tab needs to be pushed out. That will allow you to push the other white tab down. Once you see it... it's common sense
good luck
There is a tab up by the ecu box and the windshield wipers. You have to pull that and the sidemarker should pop out. I think the tab is yellow but im not sure.
Good luck
Good luck
I got the corner lights out. There isn't enough clearance for me to unscrew the 3rd torx screw. I will do it later when I have more time. The headlight is really screwed up. I tried aiming it like the article and it really didn't help. Something is amiss inside the headlight the pattern doesn't look at all like the right one.
medsurgequip
04-10-2011 05:54 PM
BSCA4
10-08-2004 03:01 PM
Sotap
04-18-2003 04:44 PM
audifull
09-29-2002 06:40 PM
