Headlight trouble
Just wondering if anyone has any idea what is wrong with my healights. They stopped working last night. I flip the switch but nothing. Any suggestions would be great!! Thanks!
I've never had it done, and since I'm in Europe, it probably wouldn't help you much anyway.
However, changing the switch involves quite a lot of work: The light switch and turn signal stalk come as a single unit. To change it, the following steps are necessary:
- Disconnect the battery.
- Remove the driver airbag.
- Remove the steering wheel.
- Remove the steering column cover.
- Remove the stalks, pull the plugs.
- Separate the light switch/turn signal stalk assembly from the wiper stalk.
- Put everything together in reverse order.
my96cab
9
09-30-2007 01:03 PM
SchwarzS6
07-06-2006 11:17 AM
19885ktqcd in Wa. st
11-06-2003 06:38 PM
