Headlight Washer Connector Wiring Problem
My headlight washers were never working, but today finally when I got a chance to replace the pump and the connector only to find out the superceded nightmare. Even though the pump was replaced it still doesn't work, I don't know if I've made a mistake putting while putting the wires into the new connector or some other problem. On the connector red wire is suppose to be in slot 2 while yellow wire is in slot 1 correct? Any help would be great because this is a PITA
The pump works fine, but when using a volt meter only the yellow wire in slot one on the connect has a response, meanwhile the red wire is dead. Can anyone provide me with the electrical wiring for the relay to pump. Many thanks.
Reifle
11-27-2006 01:05 PM
tkl999
06-12-2005 10:03 PM
Dr. Gräfenberg
10-29-2004 05:43 AM
