Heater core replacement--Need help w/ loose ends.
Got the dash out, new heater core and a/c evap core in place and I'm putting the climate control box back in. Two small problems.
1) Two clips left over. I've put in every one that's obvious. There's a place down deep in the space between the heater core housing and the a/c housing which looks like it could hold them, but it doesn't look like they'd be doing anything since they'd only clip to one side. Is there a hidden place where these fit?
2) The vaccum line that goes through the bulkhead hooks up to a solenoid, then a large white plastic reservoir, then another solenoid with two hose fittings. When I pulled it, there was a hose coming off one fitting and connected to nothing and the other fitting had nothing connected. Is this hose supposed to form a loop, or is there something else I should be looking for?
Thanks
Thanks
Should be back on the road in just a few weeks.
