heater not blowing hot
I have a 2001 a4 when you first turn on the heater it blows hot for about 10 seconds and then blows cold, the top hose is hot but the bottom one is cold, can someone help? please
ok, should I take it to jiffy lube they said they could flush out everything including heater core would cost more but things are frozen here now. just wondering if anyone has used jiffy lube for this problem.
dont use weird aditives or anything, just medium pressure water to get all the goo out
. Tell them to take out all air before altough car does it auto in a short time.
Another problem can be if engine overheats( Coolant temp is over 94C or around there), car stops coolant from entering heating core to prevent damage. This only if you have overheating...
untill 86C termostat controls, over 92C radiator fan kicks in to help.
And yeah replacing heater core is a "peach" ...
![Stick Out Tongue](https://www.audiworld.com/forums/images/smilies/tongue.gif)
You can take it anywhere you want if you trust them. Me personally, I wouldn't. Unhook the lines a flush with a garden hose. Make sure you're ready with fresh G12 to fill the coolant back up. Do not mix coolants, G12 only
I wouldn't trust Jiffy lube to do anything like that on an Audi.
If you are DIY challenged, find a good German Indy shop. There is a somewhat complicated coolant bleed procedure on an A4, slim to no chance the minimum wage guys at Jiffy lube would know how to do it. Do it wrong your car will overheat.
Bruuster
05-26-2006 02:27 PM
