Help A4 lost pwr needed towed to dealer.
Guest
Posts: n/a
My 97 1.8tqm w/ 84k, (80k on MTM chip), started losing pwr, stuttering, on the way to work. The check engine lite came on. After I stopped the car started but ran for only a few sec. the engine never got to idle speed. The car had been running fine, all maintenance done timely. It just happened all of a sudden on the way to work Thur. dealer says car has compression, they changed spark plugs, exhaust looks ok. The car runs fine for a while then misfires between diff. cylinders. I checked the archives. Possible solutions: timing belt jumped a tooth. Coil wires need replaced. Engine needs decarbon treatment. Replacement of mass airflow sensor. Bad fuel injectors, throttle valve, or fuel pump. Anyone w/ similar problems? Again this just happened all of a sudden. Dealer first thought it was the spark plugs or wires. So much for my future 100k no problem post.
Guest
Posts: n/a
Does the starter turn on demand?
Same thing happened to me in my 97 1.8TQM. Car would loose all power and then I could not start it on demand. I would have to wait five or ten minutes to start the car. Problem was immediately identified by Tischer Audi of MD as a corrupted ECU. Computer was replaced and car has sun with no problems since.
Guest
Posts: n/a
List of service items
I know that this has been listed before, but here is a list of service items that have been rectified by Audi for the '97 A4.
Bulletins for 1997 Audi A4 Quattro Sedan 4-1781cc 1.8L DOHC Turbo (AEB)
Safety Recalls
TSB Number Issue Date TSB Title RCKG OCT 97 Recall Circular KG
Service Bulletins
TSB Number Issue Date TSB Title 949801 DEC 98 Headlight Aiming with Hella Universal Beamsetter IV
379803 DEC 98 Transmission Sound Deadening Shields, Installing
209802 DEC 98 Fuel Neutralization for Fuel Tanks
019807 DEC 98 Central Locking System, Function Options
219801 OCT 98 Turbocharger Failure Due To Lack Of Lubrication
979802 SEP 98 Repairing Wiring Harness
409802 SEP 98 Front Suspension Noisy
679801 AUG 98 Floor Mat Fastener Variations
349801 JUL 98 Pre-Filled Remanufactured Transmissions
669801 MAY 98 Heating Conditions of the Outside Rear-view Mirrors
309801 MAY 98 Servicing the Clutch and Clutch Controls
009801 MAY 98 Fluid Capacity Chart
919803 MAR 98 Use Of Novelty CD's
159802 MAR 98 Torque Specification Change
379801 FEB 98 Delayed Shift, 1-2, on Cold Start Warm-up
179801 FEB 98 Oil Drain Plug Torque
649802 FEB 98 Airbag Label for Replacement Windshield
749801 FEB 98 Front Seat Backrest Panel, R&I
MAINTA9710 DEC 97 Labor Operation Revisions / Additions
MAINTA9709 DEC 97 Suggested Repair Times Microfiche
469701 NOV 97 Brake Squeal
019714 NOV 97 Diagnostic Trouble Code (DTC) Table, Additions
699703 NOV 97 Airbag Deployment
559702 NOV 97 Adjusting Rear Lid Buffer Stop
579704 NOV 97 Door Components and Seals, Servicing
729702 NOV 97 Rear Center Armrest, Removing and Installing
689707 NOV 97 Rear Three-Point Seat Belts, Removing and Installing
749701 NOV 97 Split Rear Seat Backrest Cover, R & R
709702 NOV 97 Trim, Carpeting and Center Console, R & R
MAINTA9707 SEP 97 Labor Operation Addition/Revisions
019707 SEP 97 Customer Reports Lack Of Power
289701 SEP 97 Repair Manual Updates - Ignition System
019705 SEP 97 Repair Manual Updates - On Board Diagnostic (OBD)
249702 SEP 97 Repair Manual Updates/Revisions
009710 AUG 97 Goodyear Tire & Rubber, OE Customer Service Line
A9706 AUG 97 Labor Operations
579702 JUL 97 Front/Rear Door Seals, Friction Noise
009708 JUL 97 RAPGARD, Inspection, Removal and Disposal
699701 JUL 97 Rear Child Restraint Anchorages
A9705 JUL 97 Additions/Revisions to Labor Operation Codes
A97-04 JUN 97 Labor Operation Additions and Revisions
6697-01 JUN 97 Residue On Outside Rear View Mirror Lens
A9704 APR 97 1997 M.Y. Maintenance Schedule, 45K Mile Interval
A9702 APR 97 Labor Operation Additions/Revisions
A9702 APR 97 1997/1998 M.Y. Maintenance/Lubrication Schedule
009704 MAR 97 NEW Airbag WARNING Labels, Canada Vehicles
009703 MAR 97 NEW Airbag WARNING! Labels
019703 FEB 97 Engine Cranks But Won't Start, DTC 17746 (P1338) Stored
199702 FEB 97 G12 Coolant CAUTION! Label, Installation
249701 FEB 97 Poor Idle Quality and/or Lack of Power
009702 JAN 97 Body Damage
019702 JAN 97 Remote Locking, Activation
019701 JAN 97 ABS Light ON Due to Battery Jumping/Charging
009603 DEC 96 J 1930 Nomenclature Revisions
919607 DEC 96 Trip Computer with LCD Multi-Function Display
A9602 DEC 96 Additions/Revisions to Labor Operations
139602 DEC 96 Engine Oil Seals, Lubrication Prior to Installation
019610 NOV 96 Central Locking System
929601 NOV 96 Transportation Windshield Wiper Blades
A9604 NOV 96 Correction to the 1997 Maintenance Schedule
879604 OCT 96 Air Conditioning System Changes For 1997 Model Year
199601 OCT 96 New Coolant
A9603 OCT 96 1997 Maintenance Schedule
919606 OCT 96 Cellular Telephone Installation Instructions
409602 OCT 96 Changes to Front Suspension
429602 OCT 96 Changes to Rear Suspension
479601 OCT 96 Servicing Front Brake Calipers, Bleeding/Changing Fluid
469602 OCT 96 Servicing Front Brakes, Teves Brake Calipers
449601 OCT 96 Wheel Alignment Specifications
459601 SEP 96 ABS Hydrolic Unit, Removing and Installing
019605 SEP 96 Changes to OBD For Electronic Differential Lock System
409601 SEP 96 Changes to Repair/Service Info. For Front Suspension
429601 SEP 96 Rear Strut Tool Corrections
019604 SEP 96 Data Link Connector Location
Safety Recalls
Service Bulletins
PhaZeIII
10-04-2008 10:54 PM
Jack in FL
Audi 100 / A6 (C4 Platform)
11
06-09-2001 09:22 PM
