Help, Car stutters on cold start and hunts for idle. Rattles too, dealer says bad EGR valve?
Curious if there are other little hoses that die and if I should be replacing with nice vacumm hose. BTW, the rattle is only during the warmup cycle of the EGR blower.<ul><li><a href="http://charles.rpmworks.net/a4page.htm">http://charles.rpmworks.net/a4page.htm</a</li></ul>
Why not block it off and get the claimed 5-15hp, lol!
<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1820572904&r=0&t=0">ht tp://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1820572904&r=0&t=0</a</li></ul>
It could be the gas you are using...
...I had it happen last year about this time. I switched fuel companies & it went away. Could be moisture build up in the tank after a cold winter or too high of an octane fuel (doesn't work well with low compression engines). Try the fuel first, worked for me.
Thanks for the info. I am running Union 76 instead of my usual Costoc 91.....
Though the 76 is usually a nice treat as it's true octane rating is, I am guessing a bit higher than Costco's 91. If the EGR doesn't fix things (under warranty) I'll give the gas a shot and maybe add some liquid heat moister killer stuff. Could it be a coil pack too?
davenew
04-27-2005 02:32 PM
A4GASM
12-04-2001 05:02 AM
