Help- got 2 DTC's and car stalls out while driving.
Here are my two DTC's:
2 DTCs Found:
16487 - MAF Sensor (G70): Signal too High
35-10 - - - Intermittent
16505 - Throttle Position Sensor (G69): Implausible Signal
-Also when comming to a stop my rpm's start jumping and car stalls out near idle. Can someone help me please??
2 DTCs Found:
Bentley says you need to check your MAF sensor harness for corrosion or a loose connection.
Check to see if it's damp. Also check for a firm connection and see if you need to clean out the connector for corrosion.
That is for 16487.
For 16505, it says the same thing about the throttle position sensor harness (check it and clean it). It sounds like you have an issue with the MAF sensor harness.
Hopefully that's the issue, because Bentley also says to replace the ECU if the harnesses are not the issue for the 16487 DTC.
From Bentley:
The malfunction "P0103 / 16487" is set as soon as the signal voltage rises above 5 volts for longer than 0.5 sec (engine speed below 2000 RPM).
The malfunction "P0121 / 16505" is set at a coolant temperature of over 70C (158F), enging speed between 1500 RPM and 3500 RPM for longer than 2 seconds and an engine load over 66% (Mass Air Flow sensor signal) as soon as the sensor signal voltage is less than 0.96 volts (corresponds to a throttle opening less than 12).
That is for 16487.
From Bentley:
Regl
12v V6 Discussion
08-08-2005 02:06 AM
Regl
08-06-2005 02:13 PM
ECD212 Reborn
06-10-2005 03:46 PM
