HELP!? How can I get another car's paint OFF my A4?
Guest
Posts: n/a
What the heck, you ask? My wife backed into somebody in our 3-month old A4 Avant and there's a 1 inch x 1 inch black paint 'scrape' on the car. It's definately the other cars paint because I can feel and as was able to remove some of it with WD-40 and some with my fingernail (both without hurting the paint underneath). However, it's sort of bonded on, and I'm curious about what type of cleaner/solvent I can use to more easily remove it, but without removing my silver paint underneath. Thanks for any help.
Guest
Posts: n/a
On the face of it you're asking a solvent to selectively dissolve one paint layer, of unknown formulation, without disturbing your paint/clearcoat. It may be possible but it's much more likely that if you do find a solvent that moves the black paint you'll be softening the next layer, possibly dulling it or worse!!!
I'd continue to try to rub the black paint off with a fingernail or a "spatula", softer than the Audi's finish (plastic, wood, etc). Use something like mineral spirits as a lubricant that you are sure will not soften the finish and won't leave a residue once it evaporates. Dry the area periodically and inspect to make sure that you're not abrading the surface.
If you really want to try a solvent to dissolve the black paint test it first on an inconspicuous area. Most fingernail polish removers contain methyl ethyl ketone, a very effective solvent for many finishes including car finishes.
Guest
Posts: n/a
I have succesfuly used bug and tar remover to get paint off my cars. It takes a little time and repeated applications depending on how much is on but it works and it's pretty safe.
Guest
Posts: n/a
Got a pretty nasty paint mark on a white Taurus a while ago... used some rubbing compound (i think that's what it's called) and just rubbed it away... was surprised at how well it got rid of the paint mark... however, I'm not sure if it's good for the paint... the paint looked fine to me though, so I'm assuming it's pretty safe...
guzzlerr
05-05-2003 01:52 PM
Crisqo09 T.O.
12-17-2001 05:14 PM
Bruck
08-31-2001 10:04 PM
