HELP!!!!!!!!!!!!!, im replacing rear brake pads, and im using the cube tool , with a
drill but it its not going in, ive rotated it 25 30 times and still, no result, what do i do?
If you look on the cube, it has two slots. Choose the one that almost looks like it will fit the audi piston. That shave a little off the ends, till it fits on the piston. Then attach a 10 or 12" 3/8 extension onto the cube. Hold the caliper in one hand, and turn the rachet and apply pressure as you turn clockwise if I believe. And you'll see the piston compress. It also helps if you take the cap off the brake fluid reservior, under the hood.
hope this helps.
jaime
hope this helps.
jaime
That and a deep socket worked like a charm. Here's the link to the clamp.<ul><li><a href="http://www.sears.com/sr/product/summary/productsummary.jsp?BV_SessionID=@@@@1362402664.103 0672898@@@@&BV_EngineID=cccjadcgdidlgkicehgcem gdffmdfim.0&vertical=TOOL&fromAuto=YES& ;bidsite=&pid=00931484000">http://www.s
