Help on the low down....
I have sport susp now, but looking to lower and don't want to give up to much of the ride, since I am on the road quite a bit. How much difference in ride will there be if I install Eibach or H&R springs? The Eibach's say lower by 1.4" in Front and 1.3" in Rear and the H&R's say lower by 1.3" Front & Rear.
I would love to install coilover's, but that'll have to wait for the $$$$..
Thanks for the help
Thanks for the help
difficuties referring to..
coil overs...
koni is not that difficult as long as you make sure you have the same "clicks" on both shock, i.e. same stiffness
unless you want to go back and forth to change it, then it'll be quiet a hassle because you will have to take it off to adjust it.
Further clarification...
...the height can be adjusted on all four conrners while on the car. The stiffness setting can be adjusted as well, BUT you HAVE to remove the fronts to adjust them. The rear can be adjusted while on the car.
