Help: need part# for the big bolt that holds the airbox to the engine wall and the screws that hold
Old 06-11-2001, 07:28 AM
WYSIWYG's Avatar
Default Help: need part# for the big bolt that holds the airbox to the engine wall and the screws that hold
the lower engine cover. TIA
Old 06-11-2001, 07:48 AM
bugbbq's Avatar
Default this bolt? Which bolt?
<IMG SRC="http://pictureposter.audiworld.com/12361/bolt.jpg">
you talking about the bolt that is highlighted (#6)
Old 06-11-2001, 08:47 AM
WYSIWYG's Avatar
yup, #10, #11 & #6. got the part#s? also the screws to the bottom engine cover? thanks dude
Old 06-11-2001, 09:42 AM
bugbbq's Avatar
you're getting mail!
Old 06-11-2001, 10:08 AM
WYSIWYG's Avatar
WAAAAAHOOO-HOOO-HOOO-HOOOOO thanks man
Old 02-04-2014, 10:44 PM
OldAudiA4B5's Avatar
I know this is an old thread but I'm also after the same part numbers!
Old 02-05-2014, 01:57 PM
twentysevenlitres's Avatar
Ok, the bolts referred to in post 3 as #6, #10 and #11 are a bolt (6), sleeve (10) and grommet (11).
Assuming for now you have a 1.8 - correct me if I'm wrong...
Early models (chassis number under 200,000) use an 8mm bolt:
Bolt = N 01024416 or substitute an 8x30mm bolt from a bolt shop
Sleeve = 050133861
Grommet = 050129669 (same for all models)
Later models (chassis number over 200,000) use a 6mm bolt:
Bolt = N 90632101 or substitute a 6x35mm bolt from a bolt shop
Sleeve = 058133861
Grommet = 050129669 (as above)
Old 02-10-2014, 01:56 AM
Sleeve = 050133861
Sleeve = 058133861
Cheers mate
DrCavin
14
07-10-2007 05:55 AM
Catamount90
12v V6 Discussion
05-07-2007 06:44 AM
Luxus Panzer
01-02-2006 08:07 AM
freak
05-06-2003 06:22 PM
AT
Wheels & Tires Discussion
02-05-1999 01:34 AM
Quick Reply: Help: need part# for the big bolt that holds the airbox to the engine wall and the screws that hold
