help with removing door panel. After you take the three visible screws out
Old 03-09-2001, 09:30 AM
New Member
jlh28@work's Avatar
Default help with removing door panel. After you take the three visible screws out
and remove the plastic door handle. I took the two screws out that were behind the door handle. What is next? Do you need a special tool to remove the panel. I pulled gently around the edges of the panel but it did not budge.
thanks
Old 03-09-2001, 09:37 AM
AudiWorld Uber User
eMKay (BFLO)'s Avatar
Pull straight up, it will slide right off.
Old 03-09-2001, 09:50 AM
siberian's Avatar
Ditto that... I've done it a gazillion times... just pull up.. you'll see how easy it comes off then
Old 03-09-2001, 01:41 PM
RKA
AudiWorld Uber User
RKA's Avatar
There is also a screw on the top edge of the panel.
Blewtoon
01-25-2009 09:19 AM
lgd
03-28-2007 11:56 AM
85urq
Audi Original "S" Cars
15
01-06-2006 05:29 PM
hollaatdeez
09-09-2002 02:32 PM
kilburn
06-23-2002 01:14 AM
Quick Reply: help with removing door panel. After you take the three visible screws out
