(help) replacing expansion tank, without complete drain of the coolant, is this possible?
Any one of you have any idea how this is to be done?
" Replacing the coolant reservoir/expansion tank without complete draining of the coolant"..
thanks people..
thanks people..
1. when you disconect the hose, wont be the coolant gushing all over (preasurize?)
2. do i have to bleed the coolant system when i am done with my job?
of the hose that connects to the small nipple (that appears to be your leak source)from the upper radiator pipe. Place that loose end in a suitable container, loosen the tank cap and raise the tank up as necessary to drain it. Once replaced, top off the new tank, bleed the system and you should be good to go.
do this when the car is COLD, like over night cold. there will be no pressure in the lines. just keep the open ends higher than their instaled positions. plug them with what ever fits. golf tee etc.
NiceS4
12-02-2006 07:25 PM
Blown Nogaro
9
07-15-2003 06:02 PM
ravidrabbit
06-19-2003 12:07 PM
