Help!! Timing belt replacement
Replacing timing belt on a 97 2.8 12V. The Bentley manual doesn't show an additional pulley for the fan running off the ribbed (serpentine) belt and I don't know what size hex / torx to remove it. It's the bolt underneath and behind the pulley.
It's a bitch, you need to line it up just so, to get your allens in the hole.. remove the large ones first, then get the one behind the pulley.
I read one of your posts from a while back (did my TB in 6 hours...)and found that the fan clutch was reverse threaded. I used the old serpentine belt as a strap wrench and whacked my 10" crescent wrench with a hammer. Thanks!
spiralsmurf
Audi Original "S" Cars
11
11-10-2006 11:12 AM
KaMaKaZieP -ALUMIN8-
08-31-2003 08:27 AM
Mr.D-'97 A4q 12v
07-20-2002 05:11 PM
