help.. weird ABS behavior
Re: help.. weird ABS behavior
Sounds like a Wheel speed sensor... If one of the sensors gets the axle grease on it while doing a sensor, then it will do this. If you scan the ABS module you should be able to see what sensor is throwing a code. Remove the sensor from the hub and inspect it. Clean it, see what happens.
Audi4780
08-24-2008 12:56 PM
Killer Bee
02-26-2004 06:42 AM
