Here it is! Hands free INSTALLATION!
Guest
Posts: n/a
This message is the text only. I don't yet know howto place my doc's with photos on the board. If you want the word file with the pics, e-mail me.<p>Integrating the Nokia 61xx series handsfree car kit into the Audi A4<p><br>The following article concerns my journey into the wonderful world of opening up a 30+K car.<p>Two things to note:<p>You assume all risk from using the information contained in this article <br>This article was based on an ’99 2.8 Audi A4 with the following options:<br>Bose sound system with 6 disc changer <br>Quattro <br>Tiptronic <br>All other options except sport seats and trip computer.<br>Okay, with that out of the way, here’s what I did….<p> <p>The Goal<p>I wanted to use the pre-wired features that came with the car. More importantly, I didn’t want the setup to look amateurish, of retrofit – it had to look like it was a system that was designed into the car. This meant that I was going to use all of the opportunities that presented themselves, from the standpoint of wiring and locations to place the hardware. I also did not want to make a single modification to the harness itself, ie. No cutting or splicing.<p>The Parts<p>I used the Nokia CARK-91H car kit, primarily for the privacy handset feature. The reason was not only for the added benefit of opting out of a public conversation in the cabin, but for other reasons as well that will become apparent as you read on. In addition to the car kit, I used the following components:<p>FOR MAIN MODULE (goes in cabin)<p>Two RJ45 patch cords 3-4 feet long <br>One RJ45 patch Box (looks like a wall mounted telephone jack.) <br>One RJ45 female/female coupler <br>FOR SIGNAL PATCHING (goes in trunk)<p>One DB25 Male connector <br>One DB25 serial cable male on one end, female on the other. (IMPORTANT: This MUST be a STRAIGHT THRU CABLE! Most others (for modems as an example – cross over some pin-outs.) This WILL cause damage if used.) <br>One project box about 1¼ " x 4" x 2" <br>20-24 Ga. solid core wire <br>Heat shrink tubing <br>FOR ANTENNA<p>10 feet of RG-58 Coax <br>One male mini-UHF connector <br>One female mini-UHF connector<br> <p>Please note the parts in the kit in diagram one. Like I said, the privacy handset comes either as an optional piece or in the other hands-free kit. This part is optional, and if you delete it, you will only need one RJ45 patch cable.<p> <p>PUTTING THE COMPONENTS TOGETHER<p> <p>The cabin component<p>The first thing I did was to take the speaker and mic components and cut the wires next to the housing. These components are not needed (the wiring is) since we will be using the Audi pre-wired parts instead. Then, I took the wires that were just cut and patch them into the RJ45 patch box. We’ll go over the pinouts shortly.<p>The lengths of the wires are fairly short, since you want the box near to the control unit, and I grouped them together using shrink tubing. I then took the wires from the power harness that came with the kit and patched them in also. I saved the fuses to go in the signal patching box that sits in the trunk (more on this later). <p>You will note that the green wire from the harness is not needed. It’s for a motorized antenna. The yellow wire however is very important. This is the wire that mutes the stereo when a call comes through. Both the switched and unswitched power lines are also used.<p><p>Now, the reason to use a RJ45 cable and jack is two- fold. First, the data connector in the armrest bin is an eight pin connector (RJ45). The other is that there are exactly 8 connections we are integrating into the car system.<p>Unswitched Power <br>Switched Power<br>Main Ground <br>Stereo Mute <br>Speaker positive <br>Speaker negative <br>Mic Positve <br>Mic Negative.<br>Now, as we take the wiring from the control module from the hands-free kit and tie them into the car system via the RJ45 jack box, we must make note of a.) which pin is one on the jack, and which wires go to which pin.<p>Holding the jack as shown in the photo, pin one is the leftmost one, and moves sequentially to the right (pin 8).<p>We establish the following connections:<p>PIN 1 speaker negative<p>PIN 2 mic negative<p>PIN 3 stereo mute<p>PIN 4 ground<p>PIN 5 switched 12v<p>PIN 6 unswitched 12v<p>PIN 7 mic positive<p>PIN 8 speaker positive<p>Now, pinout is important – lines 7 and 8 are SHIELDED, therefore they are used for the speaker and mike connections.<p>The RJ-45 coupler comes in a little later. You are now done with the cabin component for now.<p>You simply take each wire from the control module and tighten it to the appropriate post inside the jack. To help prevent the wires from fraying, I tin each one to bind them with solder. Now, I know that cutting the wires on the speaker and mic may make you nervous, especially at the price the kit goes for, but its all very easy to do.<p>The signaling patch component<p>Now, the RJ-45 in the cabin has no connections to the car’s systems. The task of doing that is accomplished by patching the correct system signal to the RJ-45 via the DB25 connector that is in the trunk. It’s kind of like the old telephone days, then an operator used patch cords to connect the proper people together. This part is both easy and difficult. Easy in that all you are doing is taking the signal or power from one pin and routing it to another (the RJ-45 lines). The difficult part is that there are also 8 connections to make in a small area, and you also have to patch in the fuses here.<p>First, take the male DB25 connector (I used the solder type) and patch (solder a length of wire between) the following pins:<p>PIN 3 and PIN 12 (routes PIN 4 on the RJ-45 to the car’s system ground)<p>PIN 5 and PIN 18 (routes switched 12v power (for ignition sense) to PIN 5 on the RJ45. This will eventually connect to the BLUE wire on the hands-free power harness. THIS CONNECTION MUST USE THE 1 AMP FUSE THAT COMES WITH THE CAR KIT.<p>PIN 10 and PIN 11 (routes stereo mute in the cars system to PIN 3 on the RJ-45 connector. This eventually connects to the YELLOW wire on the hands-free power harness)<p><p>PIN 8 and PIN 14 (routes the mic negative on the pre-wired Audi piece on the A-pillar to PIN 2 on the RJ-45. This eventually connects to the mic negative on the hands-free control module.)<p>PIN 1 and PIN 15 (routes the mic positive on the pre-wired Audi piece on the A-pillar to PIN 7 on the RJ-45. This eventually connects to the mic positive on the hands-free control module.)<p>PIN 16 and PIN 24 (routes unswitched 12v power to PIN 6 on the RJ45. This will eventually connect to the RED wire on the hands-free power harness. THIS CONNECTION MUST USE THE 2 AMP FUSE THAT COMES WITH THE CAR KIT.<p>PIN 6 and PIN 19 (routes the speaker positive on the pre-wired Audi piece on the door (Bose systems) or to the stereo to PIN 8 on the RJ-45. This eventually connects to the speaker positive on the hands-free control module.)<p>PIN 23 and PIN 25 (routes the speaker negative on the pre-wired Audi piece on the door (Bose systems) or the stereo to PIN 1 on the RJ-45. This eventually connects to the speaker negative on the hands-free control module.)<p>What I did was make two slots in the top of the project case for the fuses to be accessible without opening up the case if a fuse blows. This is entirely up to you. Make another opening for the DB25 connector. Attach the standoffs to secure the connector to the case. The cable will then connect to the project patch box. The reason I used the serial cable was so that I can connect one end to the DB25 connector that is in the trunk and route the patch box wherever I wanted, and have easy access without tearing up the trunk lining a second time.<p> <p> <p> <p> <p> <p> <p>INSTALLING IT ALL IN THE CAR<p> <p>The phone cradle<p>Everything from this point on is subjective. The following outlines where I put things and why, but you may want things differently. Everything up to now was required – the placement of the finished components are up to you.<p>On my car, I decided to remove the cup holders that are under the armrest. I chose this location for several reasons. One, I don’t allow anyone to eat or drink in my car, so the need for the holders were non-existent. Secondly, this location allows me to hide 99.9 percent of any external wires. Thirdly, the size of the opening and resulting cavity seems almost a perfect fit! The picture shows the cradle attached to the pivot base. I will be mounting it with the flat base, making the top of the phone flush or slightly lower than the edge of the console. Good for obscurity. Now here comes the interesting part. My armrest has the RJ-45 terminating IN the armrest bin; however, this connection leads to another connection right under the spot where the cup holders were. This is the main reason I chose the privacy set, which will become evident soon.<p>Now that the cradle is located, I want to place the control module/RJ-45 box either under the dash on the hump forward of the lower vents (a lot of room there), or behind the glove compartment. I say want to; I haven’t figured out how to get behind there yet. Perhaps someone can help me out with this in trade for this little journal. Anyway, with the module I the front, I took the main cable from the cradle, slid it between the carpet and the side of the console, and then ran the cable along side the console towards the front. I tucked it under the plastic console; there’s a lot of room to do this without deforming the side. I then plugged it into the control module. The connector looks like the RJ-45 connector on steroids.<p>Now here’s the interesting part. I UNPLUG the RJ-45 connector that is under the now vacated cupholder area. This takes the RJ-45 that is in the ARMREST BIN out of the loop. I then plug one of the RJ-45 patch cords into that connector, route it along the same path as I did for the cradle cable and plug it into the RJ-45 jack. At this point, all of the wiring for the phone is now tied into the stereo and pre-wired parts!. Now don’t get too excited, because we still need to tie the system wiring into the RJ-45 bus. That is the magic of the DB-25 connector in the trunk.<p>Before I get to the trunk, what about that connector that is left dangling under the spot where the cupholder used to be? AHHHH. Like I said, I hate to leave the installation looking amateurish. Well this is where the privacy set comes in. I take the OTHER RJ-45 patch cord, plug it into the female/female coupler, and attach it to the "dangling connector", route the cable along the same path as the other cables, and plug it into the remaining connector on the control module. That connector happens to be where the privacy handset would normally go. So what does this get you? Well, NOW YOU CAN PLUG THE PRIVACY HANDSET INTO THE JACK IN THE ARMREST BIN! No dangling cables! When the armrest is in the up position, your rear passengers can use the phone in the bin!<p> <p> <p> <p> <p> <p>The Trunk<p>Now for the most important part. As I’ve said the DB-25 connector in the trunk is the crucial link. The RJ-45 bus, and the system wiring all collect into that DB-25 connector in the trunk. Problem is, the routing of one side of the wiring is not connected to the other side, due in fact that every phone manufacturer, has a different setup, pinouts, yada, yada, yada. So it’s up to use to make the correct routing or connections. That was accomplished in the signal patch box.<p>Now you have to GET to the DB-25 connector. This area can get gray, since there may be variations among models. HOWEVER, it seems consistent that it is located near the rear wheel well, drivers side. The picture shows where I found it. I had to remove the AMP, CD changer, then carefully pull back the liner to see it. Now that you’ve found it, plug the serial cable into it. Note that the connector DOES NOT have posts for the cable to screw into. I used zip strips to ensure that they would not come apart due to vibration. Now put everything back together, and situate the patch box somewhere. I stuck it in the tool box. It’s all invisible and won’t get damaged when I load up the trunk.<p><p>You are now ACTIVE! It’s very cool to have the display read phone, mute the system, and then have hands-free kick in. Nice wow factor.<p>The Finishing Touches.<p>The photos are for indicating installation. They do not reflect how I left things in my car. Other than shortening the privacy handset cord and attaching a new RJ-45 connector to the end, the only other area that needs attention is the area under the cradle. The holes are unsightly. There are several options.<p>Since I’m an architect, I had a rep craft a piece of stainless steel with a swirled finish. The dimensions at the bottom are 7 1/16" by 2 ¾". The other option is a piece of carpet on some backing that can take the screws from the cradle base.<p>What I did was go to my Audi dealer and order part 8D0-863-301-J-1EJ. It seems there has been over the years a number of variations of inserts for this space, one of them simply a bottom liner! Well, that’s perfect. Just screw it and the cradle base down, make a slot for the cables from the cradle to the area under the lining, and it looks OEM.<p>Well, that concludes most of my experience. I hope you all find it helpful, entertaining, and perhaps even fun. If you have a different phone than the Nokia, the fundamentals are here; it shouldn’t be too difficult to make the appropriate modifications.<p> <p>Happy motoring!!!<br>
ChrisGlisson
9
08-18-2017 12:25 AM
