Hesistation/Slipping in First Gear after Cold Startup - 2.8L V6 (96 A4)
I recently experienced, a few times now, some severe hesistation, as if a clutch slipping in the transmission when I first start driving in first gear after starting my 1996 A4 2.8L V6 up when fairly cold outside (32 deg F or less). Yesterday, I started it up after work and it took off fine at first, but when I went to drive after a complete stop, it just hesistated and kept "chugging" forward like the trans was slipping until I could pull off to the side. Usually this happens upon the first time I gas it to go forward and not in reverse.
When the car is warm or has been running and shut down/restarted, I have no issue with the transmission or shifting or any hesistation whatsoever. Even after a minute or so it runs with no hesistation - only on cold start up and a quick "drive away".
The only recent repair I did was replacing the ICV valve due to poor idle. I sprayed alot of throttle body cleaner on the parts, and thought maybe some of this was still working its way through the intake. But that has been several miles ago now.
So could this be fuel delivery related or water in gas or something to that effect, or just a cold transmission oil upon startup and not priming the pump or delivering the oil to the clutch pistons to apply a clutch?
Anyone else have this issue? Any thoughts?
Transmissions are sealed units and are supposed to be lifetime maintanence free. However, many people notice q little slipping like you have here around 100k miles. Fluid changes usually breathe new life into their trannys.
How miles are on your car? If it is above 100k you could consider doing a fluid change: Click here for premium transmission fluid options.
![](http://www.ecstuning.com/product_library/27919/300/Automatic%20Transmission%20Fluid%20-%201%20Liter%20.jpg)
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!![Cool](https://www.audiworld.com/forums/images/smilies/cool.gif)
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
![](https://www.audiworld.com/forums/signaturepics/sigpic191288_1.gif)
If it is slipping then the engine will rev up, without the car moving forward normally. Is that what is happening? Low transmission fluid level could cause that symptom.
Yes, basically I was thinking it was the same thing as everyone else - low transmission fluid or just needs a change... maybe getting sludgy and not priming the trans as fast or working through upon cold startup.
Anyone know if there is a special way to check the trans fluid on this trans? While running, after hot? Anything else I should know?
Also, I noticed on ECS that there are some other fluids, yet this takes Dexron as well? Is there any one better fluid than another or one to avoid for Zed F transmissions?
Thanks!
Thanks!
Thanks!
Thanks!
audipetya
12-16-2010 12:06 PM
SOLD2000-1.8TQMSport
12-02-2003 09:57 AM
huwla
14
12-18-2002 09:50 AM
joe III
02-01-2000 04:28 AM
