Hey Digit@lex.....I changed the spark plug but the damn thing is still(more)
running like ****. I'm still missfiriing like a b!tch. Maybe after the holidays we can meet up again to do some more logging? send me an e-mail and let me know
Which means it can;t be the coil pack correct? i think maybe it is the wire or the injector. I rulled out the plug because i just changed it. Any more idea of whatit may be? cuz after that o have no idea
any chance it's been manhandled...or hasn't been installed correctly? Are the wires on both banks equal length pairs...can you swap cylinder 2 with the mirrored pair to see if the misfiring moves?
its something related to the plug...
I suspected plug wire when I rode in it... you said they were new.. but it might be worth a shot to swap it out... bad wires can happen from the manufacturer.
how did the plug look when you pulled it?
and take out my cylinder 2 wire and put in a stock one. Maybe then it will work. i'll go do it in a little bit. I hope it's the wire
The CEL won't go away (you'll need the vag for that), but if the wire is the culprit, you'll notice the misfiring stop (assuming the original set was good...was it good when you removed it?).
