hey fellas im trying to relocate the antenna to increase my remote distance...
but with all the wires that are under the seat in the back of my car I can't figure out which is the antenna...does anybody know what color it is? Pictures would be great....I found this in the tech section....Increasing the Remote Unlocking Range Phil Becker 2003
Also has anybody done this? Notice a difference?
There was a service bulletin regarding increasing its range. It talked about routing it out of the trunk and under the rear bumper area.
later years have it in the trunk someplace
96 had the worst remote range of all till I modified the antenna's location... now it gives me a good 50 -100 feet.... before I was lucky to get 5-10 feet.
I am trying to understand how you ran the wire because I have custom leather and don't have exposed pading. I assume you pointed the end of the wire towards the gas cap, did you secure it with tape?
I just did this last weekend. The unit is located in some dark gray/black padding in the back right corner of the trunk. Just remove the carpeting from that side. Then pull the unit out (black plastic - follow the instructions). Look for a brown wire (just one strand as opposed to all the others that have two). I just spliced a longer wire onto that and routed it out through a rubber gromet in the back of the trunk (unscrew and pull off that plastic liner that surrounds the locking mechanism - you'll see it). Then I just zip tied the wire under the rear bumper. Voila, better range.
If you want more info, email me at rossignol5@hotmail.com
Here's a link to the instructions:<ul><li><a href="http://www.20vturbo.com/tsb/mirror/audipdf/57-98-02.pdf">follow this</a></li></ul>
Nate (ETKA+Scumbag)
03-12-2009 08:46 PM
quattro_silver
02-08-2004 04:35 PM
