Hi all..has anyone reported a notchy clutch pedal, on top, initially upon pressing
never at idle...and only when you first press clutch pedal (at speed) then doesn't do it again until the next cycle of clutching and again, only the first press of cluth...a little notch feeling? odd...but after replacing the clutch master cylinder, it's still present...clutch engages fine and no odd sounds...running South Bend OFE (rated at 450 ft lbs.) on a Mk 1, 1.8 TT transverse engine...curious to see if you guys had similar issue
posted on TT forum but there are only 3 guys on there now and thought I'd give it a try here...Thank you!
and now the clutch comes up 3/4 but only intermittently....no fluid loss, stilll drivable...and slave and clutch has only 8k miles....can fuid in system mimic a bad slave cylinder?
nobodeuno
13
11-29-2007 07:13 AM
ePuFFy
11-18-2004 05:01 AM
miTTch
12-04-2002 08:11 AM
