Hi, is it extremely difficult to convert 99.5 headlights to Xenon? Because..
Guest
Posts: n/a
I ask the dealer in Vancouver BC, (service and parts) about ordering the kits and converting myself. They said it will cost me roughly $5000 to do it, since I have projector light on 99.5. And I cannot do it myself. Is that right? Can Xenon upgrade be DIY if I have the components? Looking forward to any reply. Thanks.
Jack
99.5 2.8QT
Garrett Tunned
Jack
99.5 2.8QT
Garrett Tunned
Guest
Posts: n/a
Uhhh,
I bought the LLtek Xenon kit for my '97 A4 for $1600 US.
I put them in myself.
$5000 CDN, sounds like typical dealer dumbness.<ul><li><a href="www.lltek.com">LLtek</a></li></ul>
Guest
Posts: n/a
Have you considered after market?
You can try www.pgperformance.com, they are in Surrey -- just a suggestion.
JY
99.5
1.8TQMS<ul><li><a href="www.pgperformance.com/subfolders/lighting/hlhid.htm">www.pgperformance.com/subfolders/lighting/hlhid.htm</a</li></ul>
JY
99.5
Guest
Posts: n/a
I have both the ECU and Tip EROM from Garrett. (I think that's what he calls the ECUs = EROM). The performance is great. It won't be dramitically different like on the 1.8T, but the perofrmance gain on 2.8 is still noticeable. The tip responses much faster than stock. And the high end power has noticeable gain. I feel like the car just keep on accelerating like there's no limit! (just my thought) Anyway, I love the chips.
Jack 2.8QT
Tunned by Garrett
Jack 2.8QT
Tunned by Garrett
Guest
Posts: n/a
You can easily purchase a HID kit that many on the net are selling now.. The 99.5 headlight assembly uses a H-7 bulb and is the easiest to convert to a D2S HID capsule.. I have done one for an A4 and also a Mercedes ML.. Light pattern is also correct due to the same placement of the light output from the H-7 bulb and the HID capsule..
DMak 1.8TQMS
DMak 1.8TQMS
Guest
Posts: n/a
www.greedspeed.com I've done business with them on and off for a little while now...they run a clean operation.
Anyhow they sell a Xenon kit which is entirely plug and play...I think this is the best option for you. I would guess they'll charge around $1400 USD for the kit.
Regards,
James R.
99 1.8TMS (Neuspeed K04, K&N Filter, Remus Exhaust, Neuspeed Sport Springs, Neuspeed Front Anti Sway, Bilstein Sport Shocks, Brembo Rotors, Mintex Red Box, Ronal R28's 17", Euro Corners, Clear Sides, Full Tint...and some other stuff I probably forgot)
Regards,
James R.
