Hi, how do I add an extra wire to ground the HID ballast?
This may sound dumb, but do I just wrap around it and connect to a ground point?? Or I have to wire it into the ballast?
Thanks.
Jack
Thanks.
Jack
i connected a 12 ga wire at the point where the ground wire from the ballast connects to the ground wire from the car (inside the headlight housing). routed it out of the housing through the little fender hole and connected it using an O ring. HTH.
from the car, ground is usually brown. But I forget what color it is inside the ecode housing. are you wiring the HIDs to valeo ecodes? The wire coming from the HID ballast was black (at least on my SPP kit). in this photo (link) ... they are the long black wires.<ul><li><a href="http://pictureposter.audiworld.com/47708/dscn0016.jpg">http://pictureposter.audiworld.com/47708/dscn0016.jpg</a</li></ul>
fenderlr
05-24-2006 04:38 AM
covertforces
06-15-2005 03:50 AM
Mirror|rorriM
08-25-2002 08:36 AM
