hit a huge pothole last night going about 40 mph... still reached destination (bowling)
but when i came out i got a flat... is it the rim? can the pothole caused just a flat? i have 16 inch swing wheels with pretty new continentals mounted on them, i would think the swing wheels are much more stronger than that to be bending just over a pothole but then again its possible, the pothole at my speed can defintely bend a rim. going to get it fixed after lunch but would like to hear some opinions first. TIA.
jack up the car, and look at the tire. If there is a hole in it...you're done. Even then...you'll need to pressurize the tire and look for bubbles in the sidewall. Based on what you're saying, the leak is kinda slow, so the shop should be able to check out the tire before removing it from the rim.
nicetts lives!
03-30-2004 09:09 AM
