home audio connection questions
i have a mid size shelf system that i am trying to hook up to a semi home system
it has only 2 rca out for surround speakers and 1 rca out for subwoofer
so i went out and bought 2 small speakers for the surround (rear) however, those speakers only has clip style speaker wires connections
the sub i have has 2 rca low level in and 4 clip style high level in.
questions is, can i use speakers wire and connect them as rca? i tried that with the surround speakers but there's a grounding problem and it keeps shorting out the system, i used a Y split for the sub and there's no signal at all
so what did i do wrong? i figure i can just get a pair of rca wire and the sub should be fine, however, what about the surround speakers?
thanks
thanks
AudiWorld Expert
Another words, this is just providing line-level signal which needs to be amplified first before going to speakers.
It also applies to the subwoofer, but since most subwoofers have a built-in amplifier (self-powered sub), then that should work just fine.
channelv
01-05-2005 07:07 PM
AUDI 90 (88)
14
06-26-2004 12:19 PM
the reverend maynard
05-07-2002 04:56 PM
selfproclaimedv8buff
04-06-2002 10:09 AM
