How to add a 4 channel amp to B5 non-bose symphony HU?
#11
The line out section of the h/u does not have female rca plugs. So you either splice in female rca's or buy one of these:
http://www.midwestelectronics.com/blaupunkt-4ch-preamp-adapter-p-161.html, it plugs straight into the line out section of the h/u.
Then just plug your 4 rca's in and run them to your 4 channel amp. The 4 rca's mean you will have full fader support.
Subs run in mono, they use a set of left and right signals, the amplifier sums these and provides the sub a combined (or mono) signal. There are lots of ways to connect the sub amplifer. The easiest is to buy a 4 channel amp that has rca outputs on it. You then run these two rca's to your sub amp. ZThen make sure you get yourself a sub amplifier that has a remote bass controller, so you have control over the subs volume from the drivers seat.
The alternative to running two amps or using a 5 channel amp is to:
- Leave the stock rear speakers as they are with there stock onboard amp (the rears are only there for fill and backseat passengers anyway)
- An alternative is to replace the stock rears with an effecient set of aftermarket speakers and use the h/u's on board amplifier to run these (these are the 2 front speaker level outs on the h/u)
- Get yourself a quality 3 or 4 channel amp (like an Audison or Zapco). Run your 4 rca's as above and use 2 channels for your new front splits and a mono channel for a sub or two.
Again, do a search of the forums. Information on how and where to run cables, splice in rca's, buy or make speaker adapters, pics, etc are all there.
Good luck.
Good luck.
B5rydin
12
04-11-2007 06:49 PM
logan15xx
08-12-2006 08:32 PM
s4Miller01
07-28-2004 01:32 PM
