how to disable washer fluid level warning on 2001 a4?
According to ross-tech, only works for 2000 or below models?
my original block 17 code was: 02242
I changed it to: 02244
nothing happened...
tried 00244 as well didnt work.
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
nothing happened...
[Select]
[17 - Instruments]
[Recode - 07]
[Do It!]
ImAwesome
01-09-2007 03:45 AM
BLKB6A402
03-14-2005 03:18 AM
TTcrane
03-15-2004 06:47 PM
