How do the *inner* CVs remove to replace boots? photos/writeup?
AudiWorld Expert
I'm doing both the inner and outer CV Boots. I found the tech for the outer ones and have one of the outer CV's off. Now how do I get the inner off? The same way???
and I think it uses a special bit to remove the bolts. Pretty straight forward and, AFAIK, the procedure for replacing the boots is the same.
Mike@PureMS will know as we removed the whole axle to do the CV boots on my car.
I assume you removed the 6 bolts and the axle is out, yes?
DO NOT TAKE INNER JOINT APART!!!
Its an extreme pain in the effing *** to get back together, it is a slightly differnt design than the outer one (it has weird tapered groves) and a pain to take apart and put back tohther, I actualy locked mine up, got friestrated and just ordered a re-man axle with brand new joints from raxles for $175.
but anyway once the axle is out there should be a snap ring on the end of the inner side.
be carefull not to pop a ball out when removing, I did, its no fun at all.
AudiWorld Expert
I have the axle on the bench, and I see the snap ring. so what do I do?
batsoff
10-30-2009 10:33 AM
Is there a write-up for just replacing the outer CV boot? The tech article has you pulling the axle.
sidespar
02-11-2008 06:33 AM
Leester
10-20-2006 01:12 PM
Mark P
14
07-06-2006 05:06 AM
