How do I remove front fogs for new bulbs?
Re: How do I remove front fogs for new bulbs?
No picture, but it's pretty easy.
1. Remove the two lower corner grilles. Push a tab at the top of each grille down with a flat head screwdriver and pull them towards you.
2. Remove the plastic cover around the fog lights. This one is held in place with a few snaps and can be just pulled back.
3. Remove the 3 philips screws holding the fog light housing in place.
4. Tilt and pull the foglight housing out.
5. Remove the harness connector. Twist and open the back of the housing.
6. Replace the bulb.
7. Assemble in reverse. When you put the fog light back in tilt it in so that the plastic pin fits in the notch. Then put the screws back in. Also before puting it back in make sure the threaded snaps which hold the screws are all in place. They can pop out.
A4wheelin
06-19-2004 01:22 PM
velo
06-27-2003 11:53 AM
T-Man
04-16-2001 06:23 PM
