How Do I reset Oil light in 96 with Vag-com????
I know I have to use the vag-com, but how do I do it? There must be someone with instructions on how to do it using vag??
I have went into instruments and adaptation, but there are no channels to change?
any ideas?
Cheers
any ideas?
Cheers
I thought I might be doing something wrong, I dont seem to have any channels available to change when I go into instruments and adaptations. Do you need the registered version of vag-com to do this?
Oil light? Add oil/Check oil level. No need to reset anything with vag.com. If it's not an oil level issue, then it's probably an oil pressure issue. Do a search and consider taking it to a mechanic asap if you think the oil pressure is the issue.
SSC
06-06-2001 01:48 PM
smythk
06-22-2000 10:50 AM
