How do I turn on the AC condenser manually to defog the interior when it is cold out (< 0C)?
Guest
Posts: n/a
It would help; defrost is less than desirable; and it will not freeze (more)...
I understand that I could turn on the defrost, but would that really turn on the condenser? The noise from the fan is less than desirable when you do so. And even if it did, it "should" be possible somehow to turn on the AC to defog the interior.
I understand of course that the air in winter is dry, but it isn't necessarily dry inside the cabin with the occupants breath etc. BTW, I don't have the recirculate button turned on, so that isn't the problem.
As far as being told that you "can't" or "shouldn't" do so, it was RECOMMENDED in my old Accord that one use the AC regularly throughout the winter (to keep the compressor motor properly lubricated, if I remember correctly).
Mac
Mac
Guest
Posts: n/a
Perhaps........
I've seen a good post somewhere where someone throughly explained AC (maybe in the FAQ) and why it can or can't be used. It only seems logical however that any condensation that would be pulled out of the air at below 32 deg. will cause frost. Actually on the AC units I've seen there is a temp probe in front of the evaporator that detects for these temps precicely for icing protection.
Your right its not necessarily dry inside the cabin but normal ventilation should "normally" take care of that given the ouside air is dry.
And yes it is recommended that you run the compressor year around for at least 5 minutes or so each week for the purposes of lubrication. But at very cold temps you don't have a choice the compressor just won't come on. Or if it does it won't stay on for long, but that may be enough for the lubrication purposes.
Don't really know why your experiencing the moisture inside the car. I've seen it while raining and 45 deg. or so but not at below freezing temps while the heater was on. Might want to try bumping up the fan speed some.
Good luck
Good luck
coupegt87
01-20-2018 09:35 PM
Greg
09-14-1999 05:40 PM
