How do my logs look?
I think the car is running strong, yet I keep fouling plugs. It looks as if I'm running a tad lean, so I increased fuel pressure just a tad.
What do you think?
<a href="http://plaza.ufl.edu/paradigm/LOG-01-002-031-032.xls">http://plaza.ufl.edu/paradigm/LOG-01-002-031-032.xls</a>
What do you think?
have been trying to find an alternate solution to raising the fuel pressure to force more fuel through the stock injectors. Installing a 5 bar fuel pressure regulator seems like a band-aid solution. I would prefer leaving the pressure at a stock 4 bar and installing larger injectors. Any advice? Also have you seen any problems running at 5 bar...burned out fuel pumps, etc.
TIA
TIA
Because there are some chips out there for the ndbw that run 310cc injectors at 3 bar and some people have even tried running the stock dbw injectors at 4 bar. Some of those that are running the J31 chip for the 2000 have found the bosch 310cc with a adjustable fpr at 3.6-3.8 bar to work very well.
those 02 readings look good, doesn't seem to be leaning out up top. As I've said before I've heard some stuff indicating that 02 readings aren't the best tuning tool. Got to get it on a dyno w/wideband anyway and see what kind of power you're putting down!
