How do you remove the coil pack?
then remove the two screws on the upper right and lower left corner of the coilpakc.. and then pull
up and out. A quick tip: make sure you have a torque wrench for doing this job, you want your plugs to be @ 22ft/lbs IIRC. If you dont torque them correctly you could have the magical coilpack problem and lose power etc.
Also, since people will most likely tell you this.. . Ill save people some typing. Try to use the B5 FAQ (you will see it in a lot of people sig's or you can search for it), or the search button for questions of this nature.
<center><img src="http://home.comcast.net/~shukanth/public.html/AEB2.jpg"></center><p>
TTRicks
09-11-2004 11:11 PM
audia4sport
11-25-2002 01:16 PM
