How do you remove steering wheel horn pad? I need to fix a buzz/rattle coming from steering wheel.
Guest
Posts: n/a
How exactly do you remove the horn pad from the steering wheel? Does it just pull off or are there screws<br>somewhere that have to be removed. I've got an annoying buzz/rattle somewhere in the steering wheel and when<br>I push or pull on the horn pad area it seems to stop. Thanks,<p>Andy Hedin<br>'97 A4 1.8Tqms, Wett 1.0 Bar, ABT Filter, Tint
Guest
Posts: n/a
There are two torx screws that come in from the back side. You'll need a torx screwdriver or bit - not sure of size, but it isn't an unusual one.<p>My car actually had a nut fall of the back of the airbag and it was rolling around in there. (If you just have a little bit of noise, this probably isn't the problem). The airbag module is attached to the steering wheel pad. I would suggest not disconnecting the wires, particularly without consulting a manual first for the proper procedure.<p>The airbag won't go off just because you remove the horn pad/airbag module, unless, of course, you do something really stupid. For the record, however, I don't recommend messing with it.
Guest
Posts: n/a
Hi Andy,<p>I took care of a buzz and a rattle coming from under my steering wheel cover a couple of weeks ago. After removing the 2 torx screws, I unplugged the air bag. I found two causes of the rattle -(1) the air bag wire was vibrating against the metal air bag base and steering wheel base, and (2) the 3 springs and floating coupling for the horn assembly needed tightening (torx again) and a spritz of lubricant. For the air bag wire, I used a pc of foam to keep it against the sw base. I did this once before without placing a pc of foam and the noise came back within a day. BTW, an otherwise great dealership, would not have put in the time to discover the noise and correct it.<p>Good luck,<br>E<br>96 A4QM<br>96 A4QM<br>86 4KS<br>P.S. I could write a book on taking apart this car..
ShoppingKartRacer
Audi 100 / A6 (C4 Platform)
02-25-2003 04:55 PM
L8APEX
09-23-2001 04:02 PM
