How do you remove the third brake light, and the rear deck- I can not find it in the Tech Section
If you have a newer A4, it should have three plastic clips across the rear deck. Those are car-seat anchors. Disconnect break light cable. Pop those off carefully. You will expose three bolts. Unbolt those and then you should be able to remove the rear deck by pulling away from window, and up slightly. Be careful not to break the deck (its that hrad cardboard stuff).
Then, you can unscrew the rear breaklight housing from the deck.
TwinTurboTerror
03-06-2005 02:31 PM
idge_ca
09-22-2003 04:37 PM
Evzen
09-10-2001 10:54 AM
Bobby Kinstle
06-29-2000 09:47 AM
Jack
09-22-1999 05:01 PM
