How hard is a head gasket R&R???(AEB)
looks like I'll be doing one soon. A wee bit of oil has been seen on the turbo side and I have lost about .5 quart in the last 5k miles.
What should I do while it is torn down? A couple of things come to mind:
cam chain tensioner and seal, valve job, powdercoat valve cover
how do you know your head gasket is failing... They dont fail with any noteworthy frequency in my experience.
oil/coolant mixing?
not holding compression /leakdown ?
I dont think a small amount of oil on the cold side of the turbo is abnormal.
.5qt in 5k miles is not alarming, which oil are you using... what condition is your breather system in?
oil/coolant mixing?
AudiWorld Uber User
yea it's generally the valve cover gasket or tensioner seal
No oil/coolant mixing, breather system works, that is all I can say about. Should replace the components??
inspect for valve cover leakage... then wait and see where the oil is coming from at the next oil change. Cam seals, valve covers, cam tensioner seals are all more common than head gaskets. I wouldnt be so chipper to get into replacing the head gasket anyways... thats a pretty nasty job.
Just ordered the parts for the PCV system. I'll monitor the seepage and try to pinpoint the source.
initialA4
03-18-2007 02:57 PM
dool
Audi 100 / A6 (C4 Platform)
03-23-2004 08:12 PM
