How important is it to change brake fluid every 2 years as per manual?
i've been going to dealer for all the services, and they seem to have missed this. I just realized it's been 4 years since they did it! The manual says nothing about doing it based on mileage, just every 2 years. As a note, I've not been driving it much per year, maybe 7,000 miles a year.
As you note, it is time not mileage based. Brake fluid will absorb moisture and becomes corrosive.
Also loses its stopping power when hot 'cause the water in it evaporates. Just get it flushed pronto.
It's not. Many cars go their entire life w/o ever a fluid change. I say do every fluid at least once
That's right, Mr. Oil Junkie said once is enough w/coolant, diffs, ATF, PS fluid and brakes. If you want longer brake fluid life, use DOT 3. End of story. Also, flushing fluid is pointless w/o depressing the caliper cyl bore....as in doing a whole brake job. I'm not trying to get out of work. Go ahead and replace the fluid 100% during a brake job. Disassemble the calipers and clean/lube guide pins with antisieze. DO NOT go running to the dealer to pay out the *** for a fluid flush mid-brake pad/job life.
End of transmission.
Holy shat........I don't even want to look at mine then.
You'll keel over if I tell you how long it's been since I last changed my fluid......... *cough* 4-5 years maybe? *cough*
Andy
Andy
the right answer: depends how agressive you drive.
for instance, if you track the car you should do it at least once a season, or you're an idiot.
since you're at double the time vs the recommendation, you should flush the fluid.
