When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Thanks for informations; but anyway, my rear (window) speakers still dont work. In the market there is a common connector which I used for connecting pt. 9 - 10 - 11, (first shown from the beginning). And then give power pt. 11 by a free lead in this connector. Now the speakers in the rear doors works, but NOT the real rear speakers. They are some strange type, I've never saw. Nokia, connected with two connector: One is a two-lead, and the second one is a 5-lead. If I disconnect fex the left rear connectors, the rear door speaker also stops working. The problem is how to connect the rear speaker to another type (Infinity Kappa). The connector I used is: Autoleads PC9-401 (Audi A3/A4/A6/A8) + the ISO connector which was in the box for the new palyer (Kenwood KDC-BT73DAB).
hey man thanks for info. but i have a audi a8 2000model. its have two front door speaker,two right door speaker, and two woofer in near back window. like you same small amp is for whom? for real door speaker or for real woofer
thanks man
god bless you
Hey everyone, So I just finished figuring out how to get my aftermarket radio working in my non-bose Symphony. I figured I would make a small write up in case anyone else ever needed the info.
The problem with this audio set up is that the two rear speakers in the car are run off a small amplifier that is attached to the rear driver side speaker. What this means is that the rear speakers cannot simply be attached to a new radio. You need to attach the 2 rear speakers to the pre-amp outputs on your aftermarket radio (RCAs).
Before I start I would like to say that it would have been much easier to simply buy this wiring harness. But, if you are so inclined, you can do it the hard way like me
Step 1:
The first step is to remove the stock radio, this is done by putting 4 pins into the 4 slots of the radio and pulling it out. Here is a picture of the 4 holes:
As far as what to put in the slots, you can easily make your own tools to remove the radio. I simply took a thin piece of sheet metal and cut out the appropriate shape:
Once you have the 4 tools just stick them in the 4 holes and pull out the radio.
Step 2: Once the radio is out all you have to do is connect all the wires. There are 4 plugs in the back of the stock radio, we will need 3 of them.
Here is a diagram with all the wires you will need:
1=Ground
2= 12v Constant
3= Illumination
4= 12v Switched
5= Front left speaker (-)
6= Front left speaker (+)
7= Front right speaker (-)
8= Front right speaker (+)
9= To rear right speaker via amp (2v)
10= To rear left speaker via amp (2v)
11= Remote turn on lead for amp
1-8 is fairly self explanatory, it's the same as any other radio install. Simply solder those wires to the corresponding wires on your new radio. 9-11 is what gave me problems.
Step 3: To power the rear speakers you need to send a pre-amp current to the little amp and you need to tell the little amp to turn on. To get it on just connect 11 to your remote turn on from your new radio (usually blue).
Now to send the current to the amp we need to make some RCAs with 9 and 10 and then connect those RCAs to the pre-amp outputs on your new radio. Buy some RCA plugs at radio shack and make something like this: Attachment 79775
The middle prong is the positive and the outer shield is the negative.
Red RCA connect wire 9 to the middle prong and connect the outer shield to the ground wire 1.
Black or White RCA connect wire 10 to the middle prong and the outer shield to ground wire 1.
Once the RCAs are made and connected to the back of the radio you can plug everything back in and slide the radio into place.
Step 4:
If you want to listen to radio you will need to buy this adaptor to be able to plug in the stock antenna. I'm sure there is a way around this and if I can find a way to do this without buying an antenna adaptor I will update this.
Step 5:
Now that all the wires are hooked up you simply have to put the radio into place. The problem is that most affordable aftermarket radios are single DIN radios (1 slot) and the whole in our dash is a double DIN (2 slots). The most simple solution is to buy this kit and install the radio in the dash as per their instructions. If you don't feel like dropping the 30$ you could always make something custom. I am currently working on mine and I will update this once it's done.
Until then my radio is just kind of sitting there:
