how long can we expect the fuel pump to last
my 96 A4 has 123,000 on it, should I just replace the fuel pump or will it tell me when its dying. I don't want to get stuck some place. what has been owners experience with the fuel pump breaking down?? how easy is it to replace. One thing I haven't done yet on the car. Still seems to be ok..
I can tell you exactly how long mine lasted; 187K. I bought a new one from highflowfuel.com in Santa Barbara CA for $87 shipped. Their own brand, it looked identical to the VDO that came out, and they claim thousands in use. Its working fine, though only a few hundred miles so far.
When the original quit, it just about left me stranded in a dangerous place in traffic, I was fortunate that the A4 coasted to a safe spot. It just totally quit without warning. When I checked for continuity at the connector later, it was completely open.
If you want to be safe and change the thing, run your gas low so you are not dealing with fuel. On my FWD '96, remove the round cover under the trunk mat, disconnect the electrical connector, the two hoses (mark flow on at least one), and unscrew the large plastic ring. There is a squeeze-connector for the fuel return line, accessible when you lift the plastic cover from its rubber gasket. Disconnect that, and pull the rubber gasket off the tank so you have more room to work. You'll see the pump assembly, which has notches in a round mounting structure. Use a long screwdriver to tap this counter-clockwise about 10 degrees, this will release the pump from the mount. When the pump is loose, you can lift it and plastic tank cover, with discharge hose between them, out of the car. There will be a crimp-clamp at the pump to pry open, to get the hose off. At this point, I made a sketch for reassembly; how the pump was orientated compared to the plastic top. Remove the nuts for the pump wires, then connect the new pump to the hose and wires. The nuts and wire terminals are different sizes so you can't mix them. I used the same clamp, after bending it back to a usable shape, then re-crimping the hose with it. Better to use a brand new one. Put it all back together, and that's it.
i have 283k miles and havent had to change it yet.
odelay12v
12-09-2003 10:21 AM
99, a4, assemblys, b5, chevy, expectancy, filter, fuel, last, life, long, pump, pumps, replacement, wwwhighflowfuelcom
