How long should it take to install an APR Stage III
Old 06-18-2004, 10:26 AM
  #11
zszabo's Avatar
Default 01.5 kit?
I have a 2001.5, I installed the kit months ago and it's been working fine.
Are you being serious?
Old 06-18-2004, 10:29 AM
  #12
EDness's Avatar
i just met up with a 01.5 stg 3 car last night...
Old 06-18-2004, 10:32 AM
  #13
Member
GrizzQuattro's Avatar
good way to put it!! :O)
Old 06-18-2004, 10:42 AM
  #14
Member
Silver Streakin''s Avatar
Default was it really made for an '01?
doubtful. just off the shelf DBW kit. not enough, IMHO.
Old 06-18-2004, 10:43 AM
  #15
Member
who? get that car on a dyno, please.
Old 06-18-2004, 10:47 AM
  #16
EDness's Avatar
Default matt2.8 came too...
Andrei...APR used his car for the 01.5. I rode in his car last year and it pulled pretty hard. My first quattro stg 3 ride.
His car looks totally stock. I'll try to get him on the dyno next time.
Old 06-18-2004, 10:49 AM
  #17
Member
Default no, I haven't figured out the boost issue. here's what I 've done so far:
I did the entire 60k, TB service. I also put on new tensioners for the extra belts.
Tstat.
H20 pump.
EFK.
Snubbie.
As many vac hoses that I could reach when the front was apart.
Replaced/tightened down some clamps that were question-able.
Some secondary breather hose was cracked. replaced.
Brake booster line replaced. the plastic part.
After all of this, I'm now holding boost to around 5k, which I really wasn't before. It was just slowly evenly falling until redline, then shift, repeat. However, it still makes a big drop at 5k and slowly falls to 10psi like it did before. So, I've been shifting at 5k all the time now.... sucks on the track.
Also, when I blip the throttle at idle, I see the vac readings kicks right at the end when the RPMs fall. never happened before. could be normal.
So, I fixed a leak - or did I? If it's willing to hold 18-21 psi for a bit, there can't be a leak. Vac readings are normal for the X.
It just won't hold boost after 5k. wtf?
I was told a coolant temp sensor could be the issue. $5. I'm going to try it.
what else could it be?
I want this resolved before I finally drop the dime on a turbo kit this summer.
Old 06-18-2004, 10:50 AM
  #18
KingA4's Avatar
yea i met andrei at short hills total sleeper car pulls hard
Old 06-18-2004, 11:30 AM
  #19
Toaster29's Avatar
What do you think is so special about the '01?
Old 06-18-2004, 11:51 AM
  #20
Raoul's Avatar
HES ALIVE!! hehe.
Quick Reply: How long should it take to install an APR Stage III
