How long would the stock clutch be expected to last if......
I were to upgrade to a Stage 3 or T-28? At present I never really launch (max 2K-2,500 while easing out the clutch). However, I do push it through the gears pretty aggressively at times once I'm going.
rpm's so it would tear it up if he didnt launch. However I don't know if a clutch suffers abuse from too much power even when fully engaged, b/c if it does then you are probly right.
That really gets to the crux of my question. It's clear to me that I would slip the clutch instantly by launching. However, will it also glaze when full boost arrives while driving?
It will certainly shorten the life, but it's probably not something you need to worry about immediately; when it goes, upgrade it.
No hard launches and no 'speed shifting' but agressive gear changes up and down.
I only upgraded because Iwanted to be able to do a few q launches ... novelty wore off quickly
