How many people are successfully using Mobil 1 75w-90 in their manual transmissions?
after recently reading the post that M1 is not gl-4 compatible it got me wondering if i should change this fluid. I'd rather not change it since i just put it in less than a year ago, but of course if it is going to hurt the transmission i will.
Hopefully it hasn't done any damage yet if it is the wrong fluid...
he said M1 is what they are told to recomend to people and that he wouldnt even bother selling me what they use there because it's twice as expensive for no reason. still not sure what i want to use now though. my 16mm triplesquare just came from ebay today though so I'm all set except for the oil
if it shifts ok, you are fine. I'd say 2 year max to play it safe. Next time use something else. Royal Purple is Dual-rated GL-4&5 and seems to be a good product. I am using RedLine. fwiw, a good rule is to change the trans fluid 2x as often as diff fluid.
I put in Mobil 1 75-90 in the A4 and, the first time I drove the car, I could tell something wasn't right. I started asking around without much success and finally called the Mobil 1 tech line. They said "Don't use it in the trans." I went back to the (go ahead and flame me) "real" Audi trans oil and everything is now back to normal. It was an expensive lesson. Next time, I'll spend more time looking for a different (i.e., cheaper) G-4 oil.
Years ago, I put Mobil 1 75-90 in the 911. The shifting never seemed quite right but I thought it was just the nature of the clunky old 915 transmission. When I switched to Swepco 201( a non-synthetic recommended by most of the Porsche guys) it made a world of difference. Apparently synthetic is too slippery for the synchros to work properly.
How Bizarre
01-25-2018 08:22 AM
jerobean
10-16-2006 04:26 AM
