How much boost are you seeing on your gauge?
Just installed a boost guage this past weekend and I'm wondering what other people are seeing on theirs.
How much vacuum do you see at idle? At cruise when on the road?
What's your max boost seen in 3rd gear? 4th gear?
What boost do you see with a Garrett stage 1 (30a) in those gears at WOT?
Thanks!
Thanks!
If your turbo is spooled up at part throttle and you suddenly open the throttle it seems pretty normal to see a short peak well above the max your car is programmed to allow. This means upwards of 15 PSI with thestock setting and >20 PSI with a 1 bar chip. This peak only lasts a couple seconds and is probably nothing more than the lag time between the system reaching max programmed boost and the appropriate bypass activating.
Tomasz@Startup
08-08-2003 08:27 AM
Ron III
02-01-1999 05:23 PM
