How is the side door trim removed/attached? Not the lower door trim...
Cant find any related articles for the side door trim, i have a gap on one of the trim pieces I want to pull off and reattach.
Its some type of two sided tape. The trim itself has pins that jet out every couple inches that help to line it up when attaching. Use a heat gun or hair dryer with a putty knife to get it off. Use the heat and goo gun to remove the tape on the trim. lay down some new tape and make sure the depth will work then reattach. Trim will line up with the holes in the door so you shouldn't have to worry about alignment.
8Pack
07-22-2008 07:38 AM
haudi
Audi 100 / A6 (C4 Platform)
05-24-2002 06:19 AM
