hydroplaning
Last week was my spring break, and I drove from Atlanta to Miami. At one point (on Alligator Alley) there was a pretty heavy downpour. A few times I felt the tail of my car swinging around, so I slowed down to around 65, at which point the tail was swaying back and forth pretty badly..I thought I was going to lose control, but luckily didn't. Same thing happened again on the way back to Atlanta.
I feel like maybe my car is more prone to hydroplaning than others I've driven in rain, but I'm not sure why. I have conti sports which have plenty of tread. Any thoughts?
Hydroplaning can occur even at 50mph. The wider your tires, the sooner your car will start floating. Once you start floating you're in deep ****.
When I got pulled, I was going 86 in the rain and the traction felt fine. Then again, I wasn't going 86 for that long before I had to slow down substantially.
If you go so fast on a wet road that you are losing grip, what do you think will happen if you have to brake all of a sudden?
Ask yourself if you will be able to slow down in time. If the answer is "no", then slow down, because you are going too fast.
Wider ='s more likely to do it. I've allways gone for max wet performance. No problem's with the dunlop sp9000's or the so3's.
-jjm
98.5 a4 2.8qms
95.5 s6 avant
-jjm
98.5 a4 2.8qms
95.5 s6 avant
s4wood
NorCal Discussion
11
03-21-2006 10:34 PM
black b7
A4 (B7 Platform) Discussion
08-30-2005 06:40 AM
dickball
12-10-2001 10:23 AM
