I can't figure out how to install the disc changer on my '01
In the little casing thingy in the trunk where the changer goes I can't figure how I am suppose to get to the screws to mount the changer. There is not enough room on the left and right side to fit a screw driver to get the changer installed. The changer did not come with instructions. Is there an easy way to get the mounting casing thing out? I see it has one bolt on each side but on the bottom it has some strange part holding it down. I am baffled here...
and then you can remove teh whole mettle assembly itself...that should work...I havent put the CD changer there put I was fiddle around with mounting a DVD player there
qfrog@work
07-17-2005 04:58 PM
jessefive
12-07-2000 08:16 AM
