i can't figure this out... my engine is flooding like nuts!
problem is fairly simple to describe...
If i put my foot to the floor i get throttle cut/surging... if i ease into it the car moves along fine ^^unchipped mode
if i put the car in chipped mode... i smell tons of gas exiting the exhaust pipe and the car runs like ****.
If i leave the car idling for more then 4-5 minutes the exhaust pipe lets out thick thick thick smoke... if i give it a bit of gas it goes away.
So ultimately this means there is a fueling issue... but what?
I have a new fuel filter... new injectors... new fuel pump relay.. new maf... new ecu...
I just got the car back from audi... after a hefty bill the problem with the grounding seems to still be there...
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-00 - -
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
so all said and done I don't know wtf is up... im going to go scan the car again and see if i clear the codes.. if any of this will go away.
any ideas?
2001.5 a4 1.9L apr stg 3+ ... quattro manual
P0106 - 35-00 - -
P1606 - 35-00 - -
P1425 - 35-00 - -
P1547 - 35-00 - -
P1117 - 35-00 - -
P1435 - 35-00 - -
P1421 - 35-00 - -
P1289 - 35-00 - -
P0238 - 35-00 - -
P1472 - 35-00 - -
any ideas?
CURRENT VAG... just did it
VAG-COM Version: Release 607.3-UD
Wednesday,12,September,2007,19:42:40
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 4B0 906 018 CH
Component: 1.8L R4/5VT G01*0002
Coding: 16001
Shop #: WSC 10002
14 Faults Found:
P0106 - 35-00 - -
P1606 - 35-00 - -
P0238 - 35-00 - -
P1472 - 35-00 - -
P1425 - 35-00 - -
P1547 - 35-00 - -
P1117 - 35-10 - - - Intermittent
P1435 - 35-00 - -
P1421 - 35-00 - -
P1289 - 35-00 - -
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 35-00 - -
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
Address 01: Engine
Coding: 16001
Shop #: WSC 10002
14 Faults Found:
P0106 - 35-00 - -
P1606 - 35-00 - -
P0238 - 35-00 - -
P1472 - 35-00 - -
P1425 - 35-00 - -
P1547 - 35-00 - -
P1435 - 35-00 - -
P1421 - 35-00 - -
P1289 - 35-00 - -
P0102 - 35-00 - -
P1115 - 35-00 - -
P1612 - 35-00 - -
Same **** that happened to me last year!!!! WAS NOT THE FUEL PUMP RELAY!!!-->
Check the wires going to the passenger side of the car, that's where all those components lead. Something shorted out and melted the wires in that part of the harness. I had to re-wire 5-6 items to make the car run right again. Runs like a top now though.
I agree. Sounds to me like he needs to go through the harness with a dog flea/tick comb. ;)
I think there is something that got pinched/kinked. Either that or a bad ECU. (not likely but I would certainly NOT rule it out)
Mandeep: Have you tried or can you try a different ECU? That would be a quick easy thing to try to at least rule it out.
