I was changing my oil filter when I noticed a bunch of crusty pink stuff around the hose...
...and the area around the filter. It appears that I may be leaking coolant. Any ideas how to fix this? New hose/new clamp??? Common?
Yup, replace the two clamps on the coolant hoses in the oil cooler just above the filter. The clamps loose their springiness over time and begin to leak. It's a bit of a pain to get them off, but it can be done. Just take the 3 screws holding the coolant expansion tank off so you can move it out of the way to make room for your hands to get down there.
Cheers,
Cheers,
Well, it doesn't require a flush, but you'll need to add G12 + distilled water to replace the coolant that leaks out when you pop off the hoses.
Cheers,
Cheers,
...have any issues...this won't be done until the weekend anyway.
sjsuQ7
Q7 MK 1 Discussion
11-12-2021 11:22 AM
x2nervisx
02-13-2010 03:33 AM
Quattromatt
04-27-2004 02:45 PM
